*DEFINE_CURVE
LS-DYNA Input Interface KeywordDefines a function using tabulated input with offsets and scales.
(1) (2) (3) (4) (5) (6) (7) (8)
*DEFINE_CURVE
Curve_ID Scale_x Scale_y Offset_x Offset_y
X1 Y1
X2 Y2
etc. etc.
XN YN
Definition
Curve_ID Curve identifier.
(Integer)
Scale_x Scaling coefficient for abscissa, non-negative.
Default = 1 (Real)
Scale_y Scaling coefficient for ordinate, non-negative.
Default = 1 (Real)
Offset_x Offset for abscissa.
Default = 0 (Real)
Offset_y Offset for ordinate.
Default = 0 (Real)
X1, X2, XN Abscissa values.
(Real)
Y1, Y2, YN Ordinate values.
(Real)
  1. This keyword maps to /FUNCT and /MOVE_FUNCT.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
