/MOVE_FUNCT
Block Format Keyword This describes the function scale and shift.
/MOVE_FUNCT/fct_ID
move_funct_title
Ascalex Fscaley Ashiftx Fshifty
Definition
fct_ID Function identifier.
(Integer, maximum 10 digits)
move_funct_title Move function title.
Ascalex Abscissa scale factor.
Default = 1.0 (Real)
Fscaley Ordinate scale factor.
Ashiftx Abscissa shift value.
Default = 0.0 (Real)
Fshifty Ordinate shift value.
  1. The function linked to this option is scaled first and shifted afterwards, as follows:
    X n e w = X o l d ⋅ A s c a l e x + A s h i f t x
    Y n e w = Y o l d ⋅ F s c a l e y + F s h i f t y
    with X o l d and Y o l d are values from function fct_ID.
  2. It is recommended that the final list of abscissa value in the function be increased (which means the abscissa value in the function needs to be greater than the previous abscissa value).
