/FUNC_2D
Block Format Keyword Defines a scalar value or a vector value defined on a subset of .
| /FUNC_2D/fct2d_ID | |||||||||
| fct2d_title | |||||||||
| dim | |||||||||
Each point per line
| X | Y | Z1 | Z2 | Z3 | |||||
Definition
| fct2d_ID | (Mandatory) 2D function
identifier. (Integer, maximum 10 digits) |
| fct2d_title | 2D function
title. (Character, maximum 100 characters) |
| dim | Dimension of the 2D
function values.
| X | Coordinate
1. (Real) |
| Y | Coordinate
2. (Real) |
| Z1 | 2D function value along first basis axis. | |
| Z2 | 2D function value along second basis axis, only used when dim=2 or 3. | |
| Z3 | 2D function value along third basis axis, only used when dim= 3. |
/FUNC_2D/1
for density initialization
# dim
1
# X Y Z1
# X-coord Y-Coord density
0.00000000 0.00000000 109.00000000
0.00195695 0.00000000 114.00000000
0.00391389 0.00000000 111.00000000
0.00587084 0.00000000 109.00000000
0.00782779 0.00000000 114.00000000
/FUNC_2D/3
for velocity initialization
# dim
2
# X Y Z1 Z2
# X-coord Y-Coord velocity x velocity y
0.00097656 0.00097656 -0.00026680 -0.02174114
0.00097656 0.00292969 -0.00080037 -0.02173459
0.00097656 0.00488281 -0.00133382 -0.02172149
0.00097656 0.00683594 -0.00186707 -0.02170185
0.00097656 0.00878906 -0.00240003 -0.02167567
#enddata
- The function may contain any number of points.
