*DEFINE_BOX
LS-DYNA Input Interface KeywordDefine a rectangular box in the global or local coordinate system.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *DEFINE_BOX_{OPTION} | |||||||
| Box_ID | XP1 | YP1 | ZP1 | XP2 | YP2 | ZP2 | |
If OPTION = LOCAL, insert the following
lines.
| X1 | Y1 | Z1 | X2 | Y2 | Z2 | ||
| Ox | Oy | Oz |
Definition
| OPTION |
| Box_ID | Box identifier. | |
| XP1 | X coordinate of first point (minimum). (Real) |
| YP1 | Y coordinate of first point (minimum). (Real) |
| ZP1 | Z coordinate of first point (minimum). (Real) |
| XP2 | X coordinate of second point (maximum). (Real) |
| YP2 | Y coordinate of second point (maximum). (Real) |
| ZP2 | Z coordinate of second point (maximum). (Real) |
| X1 | X coordinate on local 𝑥-axis. (Real) |
| Y1 | Y coordinate on local 𝑥-axis. (Real) |
| Z1 | Z coordinate on local 𝑥-axis. (Real) |
| X2 | X coordinate on local 𝑥y-vector. (Real) |
| Y2 | X coordinate on local 𝑥y-vector. (Real) |
| Z2 | X coordinate on local 𝑥y-vector. (Real) |
| Ox | X coordinate of skew origin. (Real) |
| Oy | Y coordinate of skew origin. (Real) |
| Oz | Z coordinate of skew origin. (Real) |
- If OPTION is defined, XP1, YP1, ZP1, XP2, YP2, and ZP2 are expressed in the local coordinate system.
- This keyword maps to /BOX/RECTA and /SKEW/FIX if the option LOCAL is defined.
