*DEFINE_TABLE_2D
LS-DYNA Input Interface KeywordThis keyword defines a 2D table.
(1) (2) (3) (4) (5) (6) (7) (8)
*DEFINE_TABLE_2D
table_ID SCA OFFA
A1 Curve_ID1
A2 Curve_ID2
An Curve_ID3
Definition
table_ID Curve identifier.
(Integer)
SCA Scale factor for the value An.
Default = 1 (Real)
OFFA Offset for the value An.
Default = 0 (Real)
An Value that corresponds to the following nth curve identifier.
(Real)
Curve_IDn Defined curve identifier(s).
(Integer)
  1. This keyword maps to /TABLE/1.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
