Sine-Sweep on Random Fatigue Analysis
Sine-sweep on random vibration is a superposition of swept sinusoidal vibration on random vibration. It is considered as a series of single sine tones on top of random vibration.
This is useful when the sine-sweep test rig is on a moving vehicle. An example application is to determine fatigue damage at resonance frequencies across a sweep frequency range when the structure is also undergoing a background random vibration. For instance, calculation of fatigue damage at possible resonance frequencies of sinusoidally vibrating parts inside a car driving down a bumpy road.
Damage Calculation
Damage calculation due to sine-sweep on random vibration is a similar procedure to regular random vibration fatigue (Refer to Random Response Fatigue Analysis), with some noted differences.
The vibration is considered as a series of single sine tones on top of random vibration. During sine-sweep, consider the time duration T, as the time that is spent moving from one frequency to another. Numerically, T is determined by sweep rate (SR) on a FATLOAD Bulk Data Entry and DF (or NF) on the SWEEP continuation line on a FATPARM Bulk Data Entry.
Damage is estimated for each time duration T, which is spent sweeping across a particular frequency. For each T, the spectral moments can be calculated as:
m n = k=1 N f k n G k δf+ 1 2 f A n 2 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeWabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGTbWaaSbaaSqaaiaad6gaaeqaaO GaaGPaVlabg2da9iaaykW7daaeWbqaaiaadAgadaqhaaWcbaGaam4A aaqaaiaad6gaaaGccaWGhbWaaSbaaSqaaiaadUgaaeqaaOGaeqiTdq MaamOzaiaaykW7cqGHRaWkcaaMc8+aaSaaaeaacaaIXaaabaGaaGOm aaaacaWGMbWaaWraaSqabeaacaWGUbaaaOGaamyqamaaCaaaleqaba GaaGOmaaaaaeaacaWGRbGaaGPaVlabg2da9iaaykW7caaIXaaabaGa amOtaaqdcqGHris5aaaa@5191@
Where,
n MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOBaaaa@36E9@
Moment order.
f k MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGMbWaaSbaaSqaaiaadUgaaeqaaa aa@33BF@
Frequency values for random vibration.
G k MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGhbWaaSbaaSqaaiaadUgaaeqaaa aa@33A0@
Stress PSD response value at frequency f k MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGMbWaaSbaaSqaaiaadUgaaeqaaa aa@33BF@ .
N MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOtaaaa@36C7@
Number of frequencies in stress PSD.
A MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaaeaadaaakeaacaWGbbaaaa@327E@
Stress amplitude due to the single sine tone assumed during the time duration T.
Fatigue damage is calculated based on the calculated moments, similar to Random Response Fatigue Analysis.
The total damage per sweep due to the swept sine tone on random vibration is the summation of damages during each time duration.
D = D 1 ( during t = t 1 ) + D 2 ( during t = t 2 ) + D 3 ( during t t 3 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9iaadseadaWgaaWcbaGaaGymaaqabaGccaaMc8UaaGPaVlaacIca caqGKbGaaeyDaiaabkhacaqGPbGaaeOBaiaabEgacaaMe8UaamiDai abg2da9iaadshadaWgaaWcbaGaaGymaaqabaGccaGGPaGaey4kaSIa amiramaaBaaaleaacaaIYaaabeaakiaaykW7caaMc8Uaaiikaiaabs gacaqG1bGaaeOCaiaabMgacaqGUbGaae4zaiaaysW7caWG0bGaeyyp a0JaamiDamaaBaaaleaacaaIYaaabeaakiaacMcacqGHRaWkcaWGeb WaaSbaaSqaaiaaiodaaeqaaOGaaGPaVlaaysW7caGGOaGaaeizaiaa bwhacaqGYbGaaeyAaiaab6gacaqGNbGaaGjbVlaadshacqGHsislca WG0bWaaSbaaSqaaiaaiodaaeqaaOGaaiykaaaa@6D27@ and so on across the entire sweep.
Input
A random response analysis and a frequency response analysis are underlying subcases for sine-sweep on random fatigue. In a particular FATEVNT entry, a FATLOAD referencing the random response analysis and another FATLOAD referencing a frequency response analysis should be specified to activate sine-sweep on random fatigue.
The FATLOAD data referencing the frequency response analysis should also contain the SWEEP continuation line along with the sweep rate (SR) and the sweep rate unit (SRUNIT).
As an example, consider SUBCASE 10 is a random analysis subcase, and SUBCASE 20 is a frequency response analysis subcase. The following setup showcases how sine-sweep on random fatigue is activated:
FATLOAD,100,,10
FATLOAD,200,,20
+,SWEEP,1.5,OCTPM
FATEVNT,1000,100,200
Where the sweep rate is 1.5 and the sweep rate unit is set to octaves per minute (OCTPM).
Output
General fatigue output for Damage and Life are supported. The damage output is multiplied by the number of sweeps N defined on the FATSEQ Bulk Data Entry and reported.
