Equivalent Stress Amplitude
Overview of Equivalent Stress Amplitude (EQSTSAMP).
In S-N fatigue analysis, equivalent stress amplitude ( S e q MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBa aaleaacaWGLbGaamyCaaqabaaaaa@38D8@ ) is a stress amplitude that corresponds to reported life ( N f MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOtamaaBa aaleaacaWGMbaabeaaaaa@37DE@ ) in an adjusted stress-life curve:
S e q = S R I 1 N f b MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBa aaleaacaWGLbGaamyCaaqabaGccqGH9aqpcaWGtbGaamOuaiaadMea caaIXaWaaeWaaeaacaWGobWaaSbaaSqaaiaadAgaaeqaaaGccaGLOa GaayzkaaWaaWbaaSqabeaacaWGIbaaaaaa@41B1@
In E-N fatigue analysis, equivalent strain amplitude is first obtained from an adjusted strain-life curve:
ε e q = S f ' E 2 N f b + ε f ' 2 N f c MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaadwgacaWGXbaabeaakiabg2da9maalaaabaGaam4uamaa DaaaleaacaWGMbaabaGaai4jaaaaaOqaaiaadweaaaWaaeWaaeaaca aIYaGaamOtamaaBaaaleaacaWGMbaabeaaaOGaayjkaiaawMcaamaa CaaaleqabaGaamOyaaaakiabgUcaRiabew7aLnaaDaaaleaacaWGMb aabaGaai4jaaaakmaabmaabaGaaGOmaiaad6eadaWgaaWcbaGaamOz aaqabaaakiaawIcacaGLPaaadaahaaWcbeqaaiaadogaaaaaaa@4D31@
The corresponding elasto-plastic stress amplitude can be obtained by solving the following equation for elasto-plastic stress amplitude ( σ e q MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaadwgacaWGXbaabeaaaaa@39C3@ ):
ε e q = σ e q E + σ e q K ' 1 n ' MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaadwgacaWGXbaabeaakiabg2da9maalaaabaGaeq4Wdm3a aSbaaSqaaiaadwgacaWGXbaabeaaaOqaaiaadweaaaGaey4kaSYaae WaaeaadaWcaaqaaiabeo8aZnaaBaaaleaacaWGLbGaamyCaaqabaaa keaacaWGlbGaai4jaaaaaiaawIcacaGLPaaadaahaaWcbeqaamaali aabaGaaGymaaqaaiaad6gacaGGNaaaaaaaaaa@49D1@
Finally, Neuber correction gives the elastic equivalent stress amplitude:
S e q = E σ e q ε e q MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaaBa aaleaacaWGLbGaamyCaaqabaGccqGH9aqpdaGcaaqaaiaadweacqaH dpWCdaWgaaWcbaGaamyzaiaadghaaeqaaOGaeqyTdu2aaSbaaSqaai aadwgacaWGXbaabeaaaeqaaaaa@424E@
Output Request
EQSTSAMP = SET ID gives the equivalent stress amplitude result in supported format. If multiaxial fatigue is carried out, critical plane angle is also available in the output files. The angle is measured from the local X-axis of a plane where plane stress was calculated.
