Electrostatic Analysis
An electrostatic analysis involves the calculation of electric potential in dielectric structures subjected to electrical loads.
- Electrical permittance matrix
- Electric potential
- Electric charge
This equilibrium equation of electric charge is solved for the unknown electric potential.
Electrostatic Analysis in OptiStruct
A standalone electrostatic analysis subcase in OptiStruct can be defined using ANALYSIS=ESTAT. Two types of loading can be defined in this analysis, namely charge or enforced potential which are time independent in nature. ESTAT is used for finding electric potential distribution in dielectric material, and evaluating electrostatic force on the structure, which can be used as external loading in structural analysis.
SUBCASE 1
ANALYSIS ESTAT
SPC = 1
LOAD = 2
TEMP(MAT) = 4Input
A summary of the relevant input file entries in an electrostatic analysis.
| Entry | Purpose |
| ANALYSIS = ESTAT | Defines an electrostatic analysis subcase |
| Entry | Purpose |
| SPC, SPCD | Potential |
| CHARGE | Nodal charge |
| CHGAREA | Area Charge Density |
| CHGVOL | Volume Charge Density |
| MAT1PT | Isotropic Permittivity Material |
| MAT2PT | Anisotropic Permittivity Material |
| MATT1PT, MATT2PT | Temperature Dependent Material |
| PGAPES | Electrical permittance properties for gap elements |
| PCONTES | Contact Permittance Coefficient (CPC) for CONTACT element |
Analogy
The following table summarizes the analogy of some electrical analysis entries with the existing thermal/structural analysis.
| Type | Electrostatic Analysis | Electrical Conduction Analysis | Thermal Analysis | Structural Analysis |
| Result output | Electrical potential | Electrical potential | Temperature | Displacement |
| Electrical field | Electrical field | Temperature Gradient | Strain | |
| Electrical displacement | Current density | Heat flux | Stress | |
| Loads and boundary conditions | CHARGE | CURRENT | FORCE | |
| CHGAREA | CDENST4 | QBDY1 | PLOAD4 | |
| CHGVOL | QVOL | GRAV | ||
| SPC (Electric potential) | SPC (Electrical potential) | SPC (Temperature) | SPC (Displacement) | |
| SPCD (Electrical potential) | SPCD (Electrical potential) | SPCD (Temperature) | SPCD (Displacement) | |
| MPC (Electric potential) | MPC (Electric potential) | MPC (Temperature) | MPC (Displacement) | |
| Material | MAT1PT | MAT1EC | MAT4 | MAT1 |
| MAT2PT | MAT2EC | MAT5 | MAT9 | |
| MATT1PT | MATT1EC | MATT4 | MATT1 | |
| MATT2PT | MATT2EC | MATT5 | MATT9 |
Problem Setup
Example of an electrostatic analysis.
$ EXAMPLE TO DEMONSTRATE AN ELECTRICAL ANALYSIS SETUP
OLOAD = 11
VOLTAGE = 11
GPCHARGE = 11
ESTATFORCE(COMP,ESET=10) = 20
SUBCASE 2
LABEL ELECTROSTATICS
ANALYSIS ESTAT
LOAD = 3
SPC = 10
BEGIN BULK
$ vacuum permittivity
PARAM,VAPMTV,8.8541878128130E-12
...Example
This example demonstrates the modeling of electrostatic force in an electrode system.
Non-zero SPC is applied to the grids on electrode.
Output
Supported output requests for electrostatic analysis.
| Result | Purpose | Details |
| VOLTAGE | Voltage | Available by default |
| ELECFLUX | Electric Displacement | |
| ELECFIELD | Electric field | Available by default |
| GPCHARGE | Grid Point Charge | |
| OLOAD | Applied nodal charge | |
| SPCCHARGE | Reaction Charge | |
| MPCFORCE | MPC Charge (Free Charge inducted on outer surface of a conductor) | |
| ESTATFORCE | Electrostatic force |
A charge balance summary table is available in the .out file for electrostatic analysis. This is similar to the SPCFORCE output table and consists of total applied charge and SPC charge.
