Surface condition is an extremely important factor influencing fatigue strength, as
fatigue failures nucleate at the surface. Surface finish and treatment factors are
considered to correct the fatigue analysis results.
Surface finish correction factor is used to characterize the roughness of the
surface. It is presented on diagrams that categorize finish by means of qualitative
terms such as polished, machined or forged. 1Figure 1. Surface Finish Correction Factor for Steels
Surface treatment can improve the fatigue strength of components. NITRIDED,
SHOT-PEENED, and COLD-ROLLED are considered for surface treatment correction. It is
also possible to input a value to specify the surface treatment factor .
In general cases, the total correction factor is
If treatment type is NITRIDED, then the total correction is .
If treatment type is SHOT-PEENED or COLD-ROLLED, then the total correction is = 1.0. It means you will ignore the effect of
surface finish.
The fatigue endurance limit FL will be modified by as: . For two segment S-N curve, the stress at the
transition point is also modified by multiplying by .
Surface conditions may be defined on a PFAT Bulk
Data Entry. Surface conditions are then associated with sections of the model
through the FATDEF Bulk Data Entry.
Fatigue Strength Reduction Factor
In addition to the factors mentioned above, there are various other factors that could affect the
fatigue strength of a structure, that is, notch effect, size effect, loading type.
Fatigue strength reduction factor is introduced to account for the combined effect of
all such corrections. The fatigue endurance limit FL will be modified by as:
The fatigue strength reduction factor may be defined on a
PFAT Bulk Data Entry. It may then be associated with
sections of the model through the FATDEF Bulk Data
Entry.
If both and are specified, the fatigue endurance limit FL will
be modified as:
and have similar influences on the E-N formula through
its elastic part as on the S-N formula. In the elastic part of the E-N formula, a
nominal fatigue endurance limit FL is calculated internally from the reversal limit
of endurance Nc. FL will be corrected if and are presented. The elastic part will be modified as
well with the updated nominal fatigue limit.
Scatter in Fatigue Material Data
The S-N and E-N curves (and other fatigue properties) of a material is obtained from
experiment; through fully reversed rotating bending tests. Due to the large amount
of scatter that usually accompanies test results, statistical characterization of
the data should also be provided (certainty of survival is used to estimate the
worst mean log(N) according to the standard error of the curve and a higher reliability level
requires a larger certainty of survival).Figure 2. S-N Curve with Scatter Data
To understand these parameters, let us consider the S-N curve as an example. When S-N
testing data is presented in a log-log plot of alternating nominal stress amplitude
Sa or range SR versus cycles to failure N, the relationship between S and N can be
described by straight line segments. Normally, a one or two segment idealization is
used.Figure 3. One Segment S-N Curve in log-log Scale
Consider the situation where S-N scatter leads to variations in the possible S-N
curves for the same material and same sample specimen. Due to natural variations,
the results for full reversed rotating bending tests typically lead to variations in
data points for both Stress Range (S) and Life (N). Looking at the Log scale, there
will be variations in Log(S) and Log(N). Specifically, looking at the variation in
life for the same Stress Range applied, you may see a set of data points which look
like this.
S
2000.0
2000.0
2000.0
2000.0
2000.0
2000.0
Log (S)
3.3
3.3
3.3
3.3
3.3
3.3
Log (N)
3.9
3.7
3.75
3.79
3.87
3.9
As with many processes, the distribution of Log(N) is assumed to be a Normal
Distribution. There is a full population of possible values of log(N) for a
particular value of log(S). The mean of this full population set is the true
population mean and is unknown. Therefore, statistically estimate the worst true
population mean of log(N) based on the input sample mean (SN curve on
MATFAT) and Standard Error (SE
on MATFAT) of the sample. The SN material data input on the
MATFAT entry is based on the mean of the normal
distribution of the scatter in the particular user sample used to generate the
data.Figure 4. Probability Function of the Log(N) Normal Distribution for
S-N Scatter. of a particular user-defined sample data
The experimental scatter exists in both Stress Range and Life data. On the
MATFAT entry, the Standard Error of the scatter of log(N) is
required as input (SE field for S-N curve). The sample mean is
provided by the S-N curve as , whereas, the standard error is input via the
SE field of the
MATFAT entry.
If the specified S-N curve is directly utilized, without any perturbation, the sample
mean is directly used, leading to a certainty of survival of 50%. This implies that
OptiStruct does not perturb the sample mean provided
on the MATFAT entry. Since a value of 50% survival certainty may
not be sufficient for all applications, OptiStruct can internally
perturb the S-N material data to the required certainty of survival defined by you.
To accomplish this, the following data is required.
Standard Error of log(N) normal distribution (SEon
MATFAT).
Certainty of Survival required for this analysis (SURVCERT on FATPARM).
A normal distribution or gaussian distribution is a probability density function
which implies that the total area under the curve is always equal to 1.0.
The user-defined SN curve data is assumed as a normal distribution, which is
typically characterized by the following Probability Density
Function:
Where,
The data value () in the sample.
The sample mean .
The standard deviation of the sample (which is unknown, as you input
only Standard Error (SE) on
MATFAT).
The above distribution is the distribution of the user-defined sample, and not the
full population space. Since the true population mean is unknown, the estimated
range of the true population mean from the sample mean and the sample SE and
subsequently use the user-defined Certainty of Survival (SURVCERT) to perturb the sample mean.
Standard Error is the standard deviation of the normal distribution created by all
the sample means of samples drawn from the full population. From a single sample
distribution data, the Standard Error is typically estimated as , where is the standard deviation of the sample, and is the number of data values in the sample. The mean
of this distribution of all the sample means is actually the same as the true
population mean. The certainty of survival is applied on this distribution of all
the sample means.
The general practice is to convert a normal distribution function into a standard
normal distribution curve (which is a normal distribution with mean=0.0 and standard
error=1.0). This allows us to directly use the certainty of survival values via
Z-tables.
Note: The certainty of survival is equal to the area of the curve under
a probability density function between the required sample points of interest.
It is possible to calculate the area of the normal distribution curve directly
(without transformation to standard normal curve), however, this is
computationally intensive compared to a standard lookup Z-table. Therefore, the
generally utilized procedure is to first convert the current normal distribution
to a standard normal distribution and then use Z-tables to parameterize the
input survival certainty.
For the normal distribution of all the sample means, the mean of this distribution is
the same as the true population mean , the range of which is what you want to estimate.
Statistically, you can estimate the range of true population mean as:
That is,
Since the value on the left hand side is more conservative, use the following
equation to perturb the SN curve:
Where,
Perturbed value
User-defined sample mean (SN curve on MATFAT)
Standard error (SE on MATFAT)
The value of is procured from the standard normal distribution
Z-tables based on the input value of the certainty of survival. Some typical values
of Z for the corresponding certainty of survival values are:
Z-Values (Calculated)
Certainty of Survival (Input)
0.0
50.0
0.5
69.0
1.0
84.0
1.5
93.0
2.0
97.7
3.0
99.9
Based on the above example (S-N), you can see how the S-N curve is modified to the
required certainty of survival and standard error input. This technique allows you
to handle Fatigue material data scatter using statistical methods and predict data
for the required survival probability values.
SN Curve Modification
This section describes how a slope-based SN curve is modified in OptiStruct.
If the certainty of survival is not 0.5 and standard error (SE) is not
0.0, an SN curve is modified by shifting SRI1 and FL.Figure 5.
Where z is the z-value in standard normal
distribution that corresponds to the certainty of survival.
Surface Condition and Fatigue Strength Reduction Factor
A factor for surface condition () and fatigue strength reduction factor () are applied to fatigue limit to modify
slope of the SN curve after Nc_stat cycles in the
following manner:
Where Nc_stat is the
number of cycles at static failure transition.Figure 6.
Static Failure
When a specimen fails at less than or equal to a certain low number of
cycles, the failure is not considered as a fatigue failure but
considered as a static failure. Once the failure is considered as a
static failure, the low number of cycles is defined as the number of
static failure transition cycles (Nc_stat). In
fatigue analysis, stress amplitudes are supposed to be less than the
stress amplitude (Sc_stat) corresponding to Nc_stat
in an SN curve in order to apply fatigue failure theories. If static
failure check is enabled, OptiStruct checks
whether stress or stress amplitudes in stress history is greater than
Sc_stat, and reports a warning when a stress or stress amplitude exceeds
Sc_stat.
Nc_stat can be specified directly on
MATFAT.
Sc_stat is defined via ALPHA field on
MATFAT which is a scaling factor to the
UTS to determine the static failure
stress threshold.
SN Curve Modification and Static Failure Transition:
OptiStruct modifies the user-defined SN
curve when certainty of survival is not 0.5, surface treatment is
applied, surface finish is applied, or fatigue strength factor is
applied. In the modification due to surface treatment
(Cr), surface finish (Cs), or
fatigue strength factor (Kf), SN curve is only
modified after Nc_stat because surface treatment,
surface finish, or fatigue strength factor should not affect static
failure behavior which does not follow fatigue theories.
Once static
modifies slope (b0) near UTS
so that number of cycles at UTS can be 1 as
depicted in Figure 7. During rainflow cycle counting, OptiStruct issues warning messages in the
following cases:
Stress is greater than Sc_stat in stress history (both
single SN curve and multi SN curves)
Stress amplitude after mean stress correction is greater
than Sc_stat (single SN curve).
By default, OptiStruct
checks static failure and continues to evaluate damages of remaining
stress history (CHK=CONT on
FATPARM). You can choose an option to stop
damage calculation as soon as OptiStruct
detects static failure (CHK=STOP
on FATPRM). You can also choose an option to
disable static failure check
(CHK=NOCHK on
FATPARM). If static failure check is
disabled, slope near UTS in SN curve is not
modified.
Depending on the UTS value, there
can be a special case where the calculated slope
b0 becomes 0.0. In this case damage is 1.0
for all the stress amplitudes greater than or equal to Sc_stat. If
calculated b0 is positive, OptiStruct errors out.Figure 7.
Instead of OptiStruct
calculating b0 using UTS and
Sc_stat, you can define b0
directly in MATFAT. If b0 is
defined, b0 is honored as it is. If
b0 is set to 0.0, damage at Sc_stat is 1.0,
and damage at stress amplitude greater than Sc_stat is more than
1.0.
You can choose how Nc_stat is
defined in FATPARM. You can directly define
Nc_stat. This is the default way to define
Nc_stat. The default value of
Nc_stat is 1000. Another way to define
Nc_stat is to specify Sc_stat. Sc_stat is
specified by a fraction of UTS (using
ALPHA field on MATFAT).
Default Sc_stat value is 0.9*UTS. If Sc_stat is
specified, OptiStruct calculates
Nc_stat using the slope of the SN curve after
SN curve shift due to certainty of survival.
If static failure
check is activated, static failure is reported when the maximum
stress is higher than Sc_stat or corrected stress range is more than
Sc_stat.
If static failure check (CHK on
FATPARM) is set to CONT, the
SN curve is modified so that OptiStruct
can report a damage value of 1.0 when stress range is
2*UTS and 2*UTS is smaller
than SRI1. Thus stress range higher than Sc_stat reports a damage
value different from the user-defined SN curve due to the modified
b0 slope in the picture below. If static
failure check is set to STOP, damage is greater
than 1 when stress range is more than Sc_stat. OptiStruct errors out if
2*UTS is less than Sc_stat.
Overall SN Curve Modification
Combining factors from certainty of survival, surface condition, fatigue
strength reduction factor, and static failure, the final SN curve that
is used in damage calculation is depicted in Figure 8Figure 8.
References
1 Yung-Li Lee, Jwo. Pan, Richard B. Hathaway and Mark E.
Barekey. Fatigue testing and analysis: Theory and practice, Elsevier,
2005
