Solver Cross-Sections
Create solver cross-sections on the seatbelt mesh.
Creating cross-sections allows you to automatically create solver cross-sections at a given distance from the start and end of the seatbelt.
- Select the appropriate seatbelt entity in the Seatbelt Browser, right-click and select Create Cross Section from the context menu.
 - Under the Located At section in the Entity Editor, type in values for the Distance from Start and Distance from End fields.
                Click Create.
Figure 1. Cross Section
