Define a Tracking System By Component
From the Create tools, select .
- From the Tracking panel, select a tracking system from the Tracking Systems list.
- From the Track drop-down menu, select Component.
Select a component which will be used to define the tracking system.
- Click the Component input collector and select By ID.
- Pick a component directly from the model in the modeling window.
Under Displacements, use the check boxes to select the axes along which the
view will be constrained.
Option Description Global X Locks the view to the X position of the selected entity as it moves. The entity appears to remain stationary along the global X direction during animation. Global Y Locks the view to the Y position of the selected entity as it moves. The entity appears to remain stationary along the global Y direction during animation. Global Z Locks the view to the Z position of the selected entity as it moves. The entity appears to remain stationary along the global Z direction during animation. - Optional:
Activate the Lock rotations check box to lock the
rotational movement of the selected entity.
Entities can be tracked with respect to rotation.
Click the Start/Pause Animation button (on the Animation
toolbar) to animate the model.
The model is animated with respect to the component.Tip: A new component can be defined and tracked at any time during animation by picking a different component in the modeling window.
