Change a Tracking System Mode to Window Based
HyperView supports both model based and window based tracking systems. By default, a newly created tracking system will be model based. Tracking systems still belong to a particular model and are still defined using entities from a particular model, however the mode for a tracking system can now be set to either model based or window based.
From the Create tools, select .
- From the Tracking panel, select a tracking system from the Tracking Systems list.
- Activate the Window track check box.
