Change the Display Options
From the Plot tools, click the Contour tool.
- From the Contour panel, click the Display tab.
Activate the Discrete color check box to Produces
discrete color bands on contour plots with distinct boundaries between contour
levels.
This option uses a texture mapping capability in your graphics card. If your graphics card does not support texture mapping, the performance may slow down.
Activate the Interpolate colors check box to interpolate
the contour colors from the undeformed shape, with a zero value, to the result
variable reported from the solver.
If you do not select Interpolate colors, the contour colors remain the same for all frames. This is only applied to Modal and Interpolation (formerly Linear Static) animation.Note: The changes are automatically applied to the model as you enter information.
