Record View allows you to record the current view in the HWC Console and HWC log file.
It records three commands to set the view projection, view matrix, and view clipping
region in one line so that when HWC scripts are run in batch mode, the exact view
will be reproduced.
Note: The With Masking feature available in
Views, which can be saved in HyperView, is not
supported in the recording.
