Use Scalable Fonts under Linux to Render Text
HyperView uses scalable fonts for Linux to render text in the 3D window.
Installing and Configuring Scalable Fonts
It is important that the correct fonts are installed for your operating system. Issue the
command xlsfonts | grep 0-0 | grep iso8859-1
to list the fonts. By default,
HyperView uses Helvetica and Times. Under RHEL7 and RHEL 7,
the fonts list should include b&h luxi sans, b&h luxi serif as well as several other
typeface families. On SLES 12, the font list should include b&h luxi sans, b&h luxi
serif, bitstream vera sans, and bitstream vera serif.
Configure Missing Scalable Fonts on Linux for SLES12
Verify that
XFree86-fonts-scalable
andxfs
are installed. -
Use
chkconfig
as the root user to ensurexfs
is configured to run under run level 5. -
You may have to add
FontPath "unix/:7100"
under the Files section of/etc/X11/XF86Config
Configure Missing Scalable Fonts on Linux for RHEL6 and RHEL7
Verify that the following packages are installed:
fonts-xorg-100dpi fonts-xorg-base urw-fonts bitstream-vera-fonts fonts-xorg-75dpi xorg-x11-xfs
Use
chkconfig
You may have to add
under the Files section of/etc/X11/xorg.conf
Verify the X Window Server is Properly Configured for the Correct Display DPI Setting
xdpyinfo
and examine the section starting with
"screen #0
". It should look like this:
screen #0:
dimensions: 1280x1024 pixels (361x271 millimeters)
resolution: 90x96 dots per inch
Manually Set the Display Resolution on Linux Systems with NVidia Drivers
As the root user, edit /etc/X11/xorg.conf or
XF86Config
Under the Device section, add the following lines:
Option "UseEdidDpi" "false" Option "DPI" "96x96"
Manually Set the Display Resolution on Linux Systems with ATI FireGL Drivers
For RHEL with Gnome and the gdm display manager:
Edit /etc/gdm/custom.conf and add a section that reads:
[server-Standard] name=Standard server flexible=true command=/usr/bin/Xorg :0 -br -dpi 96
For RHEL 6:
The gdm configuration appears to currently be broken in terms of accepting custom parameters for the X server. You can install kdm, and specify that kdm be the default login display manager by editing /etc/sysconfig/ desktop to read:
DISPLAYMANAGER="KDE"
Edit /etc/kde/kdm/kdmrc and append "
-dpi 96
" to the line beginning with "ServerArgsLocal
" so that it reads:ServerArgsLocal= -nr -dpi 96
For SLES 12 with KDE:
Edit /etc/sysconfig/displaymanager and append "
-dpi 96
" to the line beginning with "DISPLAY_MANAGER_KDM_LOCALARGC=
" so that it reads:DISPLAY_MANAGER_KDM_LOCALARGC="-dpi 96"
