Active Model
The Active Model feature allows you to cut, copy, or paste the active model into another window.
Note: For the right-click option to work, you must
set your right mouse button to the Context Menu option. You can do this by selecting the
Mouse tab from the dialog.
![](../../images/post_processing/active_model_cntxt_menu.png)
The Cut model option is a one time only action which will not
take effect until the Paste model action is completed in a different
window. The Copy model option copies the active model and its
attributes to a buffer, which then allows the copied contents to be pasted into multiple
windows. If the target window already has a model loaded, the cut/copy contents will be
overlaid with the existing model.
Tip: You can also use keyboard shortcuts to cut
(Ctrl+X), copy (Ctrl+C), or paste
(Ctrl+V) the active model in the modeling window.
