Output Responses
An output response is a measurement of system performances, such as mass, volume, displacement, stress, strain, or reaction forces.
Create and define the output responses that will be used in DOE, Optimization, and Generative Design explorations.
Restriction: Not all output responses are available for Generative Design explorations. The following output responses are available for Generative Design:
Note:
  • Some Generative Design output responses will be automatically created based on existing Topology Optimization responses.
  • OptiStruct Topology responses are not the same as Design Explorer output responses.
