Create Force Responses
Use the Force tool to create force responses from 1D elements or constraints.
  1. From the Design Explorer ribbon, click the Force tool.
  2. Click the guide bar selector and choose whether to create the response using 1D Elements or Loads.
  3. Optional: Check the Create one response for each selected entity option.
  4. Select entities.
    If the option above is unchecked, selecting the first entity will create a response. If the above option is checked, a response will be created for each selected entity.
  5. Optional: Make any desired modifications to the created response in the microdialog.
  6. Optional: In the microdialog, select Objective or Constraint to simultaneously create one.
    Note: You can continue to define the constraint in the microdialog.
