Create Connector Responses
Use the Connector tool to create connector responses. The resulting response is the number of realized connections in the entire model or in selected connectors.
Restriction: Connector responses are not available for Generative Design
                explorations.
                From the Design Explorer ribbon, click the Connector
                    tool.
 - Optional:
                Select connectors.
                If no connectors are selected, then the response will be the number of realized connections in the entire model.
 - Optional:
                In the microdialog, select
                        Objective or Constraint to
                    simultaneously create one.
                Note: You can continue to define the constraint in the microdialog.
                On the guide bar, click
 to
                    create the response.
