Create Mass, Volume, and Compliance Responses
Use the Mass/Volume tool to create mass, volume, and compliance responses. The resulting response is the mass, volume, or compliance of the entire model or the mass of an individual property or material.
Restriction: Volume responses are only available for the OptiStruct profile.
From the Design Explorer ribbon, click the Mass/Volume
tool.
Depending on the response type being created, complete one of the following
processes.
Response Type Steps Mass - From the guide bar, select Mass.
- If using the OptiStruct profile, select a single
property, material, or element.Note: When a mass response is requested by property or material for the entire model, it is evaluated based on the solver output. When it is requested by element, it is evaluated using the HyperMesh model.
- On the
guide bar, click
. - In the
microdialog, select
Objective or
Constraint to simultaneously create
one.Note: You can continue to define the constraint in the microdialog.
Volume - From the guide bar, select Volume.
- On the
guide bar, click
. - In the
microdialog, select
Objective or
Compliance - From the guide bar, select the response type.
- On the
guide bar, click
. - In the
microdialog, select
Objective or
- Click
to
pick the load case.
On the guide bar, click
to create the response.
