Quantity computation on points: open / close a session
Open a session
To open a current point computation session:
Step Action
1 Activate the command Open a session (see image)
→ The computation session is open.
2 Consult the computed values in the table of results
To open the session directly:
  • in the data tree double-click on the entity of point computation.
Note: To open a contextual menu, use the right button of the mouse.
Close the session
To close the current point computation session:
Step Action
1 Activate the command Close a session (see image)
→ The computation session is closed.
