Quantity computation on points: new session
Create a session
To create a session Quantities computation on point:
Step Action
1 Activate the command New session (see next block)
→ A dialog box New computation session is open
2 Enter the name of session and the associated comment
3
Define physical quantities:
  • select spatial quantities (using a quantity selector)
  • or enter formulas (using a formula editor)
  • click on OK
→ A computation session is open.
To activate the command New session, choose one of the methods presented in the figure below:
To open the New session dialog box directly:
  • in the data tree double-click on the entity-type.
