Creating the Bent Dipole
Create the bent dipole using a polyline.
On the Construct tab, in the Create Curve group, click the
Polyline icon.
Figure 1. The Create Polyline dialog showing the default values. Active fields are outlined in yellow.
Note: Default values are used on geometry creation dialogs to allow a preview in the 3D view. You may change the values as required.Tip: An active field allowing point-entry is indicated by a yellow outline.Point-entry allows a variable or named points to be entered by pressing Ctrl+Shift+left click on a variable or named point in the model tree.
Create a polyline.
Modify the origin and orientation of the polyline.
- Click the Workplane tab.
- Click Custom workplane.
- Under Origin, in the X field, enter d.
- Under U Vector, in the X field, enter -1.
- Click Create to create the polyline and to close the dialog.
