Setting the Simulation Frequency
Specify the frequency range of interest. For this example, a single frequency point is used.
On the Source/Load tab, in the
Settings group, click the
Frequency icon.
A variable was created at the beginning of the example that contains the
solution frequency.
In the Frequency (Hz) field, enter
freq.
Figure 1. The Solution Frequency dialog.
Click OK to set the frequency and to close the
dialog.
Note: With the frequency set to freq, the actual frequency is 299.792 MHz. In the model tree, click the Configuration to view the specified simulation frequency.
