- Example Overview
Calculate the transmission and reflection coefficients of a waveguide power divider.
- Topics Discussed in Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
- Example Prerequisites
Before starting this example, ensure that the system satisfies the minimum requirements.
- Creating the Model in CADFEKO
Create the model geometry using the CAD component, CADFEKO.
- Launching the Solver
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated automatically for all voltage and current sources in the model.
- Reviewing POSTFEKO and Launching OPTFEKO
Open POSTFEKO from within CADFEKO.
- Final Remarks
This example showed the construction, configuration and solution of a waveguide power divider. The model consists of a hollow cuboidal sections with a cylinder (pin) in the centre. The near field and input reflection coefficient was calculated and displayed.
