- Example Overview
Consider the coupling between a monopole antenna and a loaded transmission line above a ground plane.
- Topics Discussed in Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
- Example Prerequisites
Before starting this example, ensure that the system satisfies the minimum requirements.
- Creating the Model in CADFEKO
Create the model geometry using the CAD component, CADFEKO.
- Launching the Solver
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated automatically for all voltage and current sources in the model.
- Viewing the Results in POSTFEKO
Display the model as well as the results using the post-processor component, POSTFEKO.
- Final Remarks
This example showed the construction, configuration and solution of an EMC coupling scenario. The model consists of a monopole antenna and transmission line on an infinite PEC ground plane. Coupling of current into the transmission line is viewed from 1 MHz to 30 MHz.
