Consider the coupling between a monopole antenna and a loaded transmission line above
a ground plane.
Create the monopole antenna using a line and the loaded transmission line using a
polyline. The ground plane is modelled using an infinite ground plane. Figure 1. The monopole antenna and the loaded transmission line above an infinite
ground plane.
