Specifying the Optimisation Parameters
Specify the optimisation parameters. Choose from existing variables and specify their minimum and maximum values
In the model tree
(Construction tab), select the relevant search.
On the Request tab, in the Optimisation group, click the
icon.
Populate the fields on the Modify Optimisation Parameters
dialog as given in the table.
Variable Min value Max value Start value alpha 20 110 80 d 0.7 0.9 0.8 - Click OK to set the parameters and to close the dialog.
