Rename
How to rename a library?
Table 1. How to rename a library?
1 Right Click on the library to be renamed. A drop-down menu appears with functions such as Browse, Default, Rename, Unload and Delete. Select Rename
2 When Rename is selected, the dialog box is opened to allow renaming of the selected library.
Give a new name to the selected library.
Note: A default new name is proposed. One must choose a name that is not already used in the Part Library.
