SS-T: 4005 Structural Sequential Analysis
Tutorial Level: Intermediate Run structural sequential (loading and unloading) analysis.
- Prerequisites
- Some features used in this tutorial are only available in the SimSolid Advanced version. Switch to Advanced to complete this tutorial.
- Purpose
- SimSolid performs meshless
structural analysis that works on full featured parts and assemblies, is
tolerant of geometric imperfections, and runs in seconds to minutes. In this
tutorial, you will do the following:
- Learn how to setup structural sequential analysis.
- Review results of sequential loading and unloading.
- Model Description
- The following model file is needed for this tutorial:
- tension_clip.ssp
Open Project
- Start a new SimSolid session.
In the main window toolbar, click Open Project
- In the Open project file dialog, choose tension_clip.ssp
- Click OK.
Create Structural Linear Analysis
Structural >
Structural
linear.
The new analysis appears in the Project Tree
under Design study 1 and the Analysis Workbench
opens.
Create Immovable Support
- In the Analysis Workbench, select .
- In the dialog, verify the Faces radio button is selected.
In the modeling window, select the face(s) highlighted in
orange in the figure below.
- Click OK.
Create Bolt Tightening Load
In the Analysis Workbench, click Bolt/Nut
Tightening
Select the nut.
- For Thread pitch, enter 1 mm.
- Select the Target axial load radio button and enter 3000 N.
- Click OK.
Create Sequential Analysis (Loading Step)
- On the main window toolbar, click .
In the Structural sequential setup dialog, ensure
Structural 1 is selected and click
OK.
The new analysis (Structural 2, Linked to Structural 1) appears in the Project Tree under Design study 1 and the Analysis Workbench opens.
Create Sequential Force
- In the Analysis Workbench, click .
- In the dialog, ensure the Faces radio button is selected.
In the modeling window, select the face shown in Figure 3.
Figure 3.
- For Y direction Force, enter 1000 N.
Click OK.
The new force, Force/Displacement 1, appears in the Project Tree. Vectors representing the load are shown in the modeling window.
Create Sequential Analysis (Unloading Step)
In the Project Tree, right-click on
Structural 2, Linked to Structural 1 and select from the context menu.
The new analysis (Structural 3, Linked to Structural 2) appears in the Project Tree under Design study 1 and the Analysis Workbench opens.
Remove Force from the unloading step.
- In the Project Tree under the Structural 3 analysis, right-click Force/Displacement 1 and select Delete from the context menu.
Edit Solution Settings
- In the Analysis branch of the Project Tree, double-click on Solution settings: for Structural 1.
- In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
- Click OK.
- Right-click on Solution settings and select Apply to all analyses in the current design study to apply the Global+Local adaptation to all other analyses in the study.
Run Design Study
- In the Project Tree, select Design study branch.
Click Run All Analyses
- In the Solver Manager, verify all analyses are selected.
Click Solve.
SimSolid runs all analyses in the design study branch. When finished, a Results branch for each analysis appears in the Project Tree.
Compare Results
Review the results for Structural 1, Structural 2, and Structural 3.
Structural 1 simulates pre-tensioning of the nut, Structural 2 simulates
loading the part, and Structural 3 simulates unloading.
