Boundary Conditions
SimSolid Boundary Condition tutorials focus on applying various external loads and constraints to your models. They cover applying imported data like forces and displacements (including via .csv files onto specific spots), setting up specialized loads such as bearing loads and hydrostatic pressure, defining thermal effects (expansion/shrinkage and steady-state analysis with solar load), applying wind load, and utilizing springs and mass definitions. The set also includes an advanced example integrating non-linear separating contact with bolt pretensioning.
