SS-T: 3020 Bearing Loads
Tutorial Level: Intermediate Create bearing loads in SimSolid.
- Purpose
- SimSolid performs meshless
structural analysis that works on full featured parts and assemblies, is
tolerant of geometric imperfections, and runs in seconds to minutes. In this
tutorial, you will do the following:
- Learn how to create bearing loads in SimSolid.
- Model Description
- The following model file is needed for this tutorial:
- BearingLoads_Crankshaft.ssp
Open Project
- Start a new SimSolid session.
In the main window toolbar, click Open Project
- In the Open project file dialog, choose BearingLoads_Crankshaft.ssp
- Click OK.
Create Structural Linear Analysis
Structural >
Structural
linear.
The new analysis appears in the Project Tree
under Design study 1 and the Analysis Workbench
opens.
Create Immovable Support
- In the Analysis Workbench, select .
- In the dialog, verify the Faces radio button is selected.
In the modeling window, select the face(s) highlighted in
orange in the figure below.
Click
OK.
The new constraint, Immovable 1, appears in the Project Tree. A visual representation of the constraint is shown on the model.
Create Hinge Support
- In the Project Tree, open the Analysis workbench.
Figure 3.
- Click Apply.
Click
Close.
A new hinge constraint appears in the Project Tree.
Apply Bearing Load
On the Analysis Workbench toolbar, click
(Bearing loads).
In the modeling window, select faces as shown in Figure 4.
Figure 4.
- For Load, enter 100 in the Radial direction.
Under Direction, for X enter 0.00000, for Y enter
0.00000, and for Z enter
-1.00000.
Tip: You can also edit Direction by using the slider bar, the spin wheel, or by entering the angle.
- For Load span and angle, enter 120.
- Click Apply.
Repeat steps 1 through 6 by selecting the faces shown in Figure 5
Figure 5.
- Under Direction, for X enter 0.00000, for Y enter 0.00000, and for Z enter 1.00000.
- Click Apply.
- Click Cancel.
Edit Solution Settings
- In the Analysis branch of the Project Tree, double-click on Solution settings.
- In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
- Click OK.
Run Analysis
- In the Project Tree, open the Analysis Workbench.
Click
Solve.
Review Results
toolbar, click
Results plot.
Select Displacement Magnitude.
The Legend window opens and displays the contour plot.
Figure 6.
