SS-T: 3040 Hydrostatic Pressure
Tutorial Level: Intermediate Create hydrostatic pressure in SimSolid.
Purpose
SimSolid performs meshless structural analysis that works on full featured parts and assemblies, is tolerant of geometric imperfections, and runs in seconds to minutes. In this tutorial, you will do the following:
  • Learn how to create a hydrostatic pressure load.
Model Description
The following model file is needed for this tutorial:
  • HydrostaticPressure.ssp
This file has the following specifications:
  • Material is set to Steel for all parts.
  • Regular connections with 3mm gap and penetration tolerance.
  • Bonded contact conditions are created automatically.
Open Project
  1. Start a new SimSolid session.
  2. In the main window toolbar, click Open Project .
  3. In the Open project file dialog, choose HydrostaticPressure.ssp
  4. Click OK.
Create Structural Linear Analysis
In the main window toolbar, click Structural > Structural linear.
The new analysis appears in the Project Tree under Design study 1 and the Analysis Workbench opens.
Create Immovable Support
  1. In the Analysis Workbench, select Constraints > Immovable support.
  2. In the dialog, verify the Faces radio button is selected.
  3. In the modeling window, select the face(s) highlighted in orange in the figure below.
  4. Click OK.
    The new constraint, Immovable 1, appears in the Project Tree. A visual representation of the constraint is shown on the model.
Apply Gravity Load
  1. In the Project Tree, open the Analysis Workbench.
  2. In the workbench toolbar, click Gravity.
  3. In the dialog, for Load direction vector, enter: [0,0,-1] for X, Y, and Z respectively.
  4. For Amplification factor, enter 1.
  5. Click OK.
Apply Hydrostatic Pressure
  1. In the Project Tree, select Structural 1.
  2. In the Analysis Workbench toolbar, select Pressure > Hydrostatic pressure.
  3. In the modeling window, select the face as shown in orange in Figure 3.
    Figure 3.
  4. Enter coordinates for the liquid surface.
    1. Under Coordinates of a point for liquid surface, for X, enter 0.
    2. For Y, enter 0.
    3. For Z, enter 60000.
    The Liquid surface indicator will appear in the model.
    Tip: You can also position the liquid surface using the sphere at the center of the indicator.
  5. For Liquid density, enter 1000.
  6. Click OK.
Edit Solution Settings
  1. In the Analysis branch of the Project Tree, double-click on Solution settings.
  2. In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
  3. Click OK.
Run Analysis
  2. Click Solve.
Review Results
  1. In the Project Tree, Select the Structural 1 subcase.
  2. In the Analysis Workbench, select Result plot > Displacement > Displacement Magnitude.
    The Legend window opens and displays the contour plot.
    Figure 4.
