SS-T: 3000 Non-linear Separating Contact and Bolt Pretensioning, Hanger Beam
Tutorial Level: Advanced Perform non-linear separating contact analysis and setup bolt/nut tightening loads.
Prerequisites
Some features used in this tutorial are only available in the SimSolid Advanced version. Switch to Advanced to complete this tutorial.
Purpose
SimSolid performs meshless structural analysis that works on full featured parts and assemblies, is tolerant of geometric imperfections, and runs in seconds to minutes. In this tutorial, you will do the following:
  • Perform assembly analysis
  • Perform non-linear separating contact analysis
  • Use SimSolid bolt tensioning functions
  • Compare SimSolid results with those obtained in traditional FEA.
Model Description
The hanger beam model in this tutorial has 70 parts, 16 bolts/nuts, and 32 washers.
The following files are needed in this tutorial:
  • Hanger beam.x_t (CAD source file)
  • Hanger Beam.ssp (SimSolid project files with the first load case solved. This is where you start the tutorial.)
  • Hanger Beam SOLVED.ssp (SimSolid project file with all load cases solved. Provided as a reference.)
Important: The introductory steps of this tutorial provide information on how the first analysis was created. If you wish to skip this, go straight to Open Project.
Open Project
  1. Start a new SimSolid session.
  2. In the main window toolbar, click Open Project .
  3. In the Open project file dialog, choose Hanger Beam.ssp
  4. Click OK.
Create Non-linear Separating Contact Analysis
  1. In the Project Tree, right-click Structural 1 and choose Copy.
    The copy will appear as Structural 2 in the Project Tree.
  2. Under Structural 2, right-click on Setup and choose Edit.
  3. In the dialog, select the Separating contact check box.
  4. Click OK.
Edit Contact Conditions
  1. In the Bookmark browser, click Bookmark 5.
    Figure 3.
    The modeling window updates with the saved view.
  2. In the modeling window, right-click on the Hanger beam (shown in orange) and select Review part contact conditions.
    Figure 4.
  3. In the dialog, hold down Control and click to select Connection 120 and Connection 121.
  4. Click Edit contact conditions.
    Figure 5.
  5. In the Contact conditions dialog, select Structural 2.
  6. Activate the Separating radio button.
    Figure 6.
  7. For the Friction coefficient, specify 0.1.
  8. Click OK.
Run Analysis
  1. In the Project Tree, open the Analysis Workbench.
  2. Click Solve.
Compare Results
  1. In the Project Tree, select the Structural 1 branch.
  2. In the Bookmark browser, choose Bookmark 3.
    This bookmark shows the deformation detail.
    Figure 7.
  3. In the Project Tree, select the Structural 2 branch.
    The modeling window updates to show deformation detail for Structural 2.
  4. Optional: Switch back and forth between Analysis branches to highlight the differences in the results.
  5. Repeat steps 1 through 4 for Bookmark 4 (stress detail).
    Figure 8.
View Separation and Contact Forces
These forces are represented as colored values at each connection point (not a true contour). You used increased resolution when creating connections to get a denser array of points to plot.
  1. In the Project Tree, select the Results branch under Structural 2.
  2. On the Analysis Workbench, select Contact Response.
  3. In the Response at connections dialog, hold down Control and click to select Connection 120 and Connection 121.
  4. Select the response type you wish to view.
  5. Use the slider to increase or decrease the size of the colored points.
    Figure 9.
  6. Click Close.
Setup Bolt/Nut Tightening
  1. In the Project Tree, right-click on Structural 2 and select Copy.
    The copy appears as Structural 3 in the Project Tree.
  2. In the Bookmark browser, select Bookmark 5 (Bolted joint).
  3. Verify Structural 3 is selected in the Project Tree.
  4. In the Analysis Workbench toolbar, click (Bolt/nut tightening) .
  5. In the modeling window, select the 4 nuts attached to the hanger beam as shown in Figure 10.
    Figure 10.
  6. For Thread pitch, enter 1 mm.
  7. Activate the Target axial load radio button and enter 5000 N.
  8. Click OK.
Run Analysis
  2. Click Solve.
Compare Results
    Figure 11.
    Figure 12.
Compare with Traditional FEA
  1. Use the model files to run this same analysis with your traditional FEA application.
    Important:
    • Do not merge or simplify geometry, use bonded and sliding contact same as SimSolid.
    • Check for part overlaps
    • Make sure element density is acceptable for smaller parts
  2. Compare the following between the two programs:
    • Solution quality
    • Number of workflow steps required
    • Time required to mesh
    • Time required to solve
    • Time required to examine results
    • Time required to refine and rerun model
