SS-T: 3055 Structural Thermal Steady-state Analysis with Solar Load
Tutorial Level: Intermediate
- Purpose
- SimSolid performs meshless
structural analysis that works on full featured parts and assemblies, is
tolerant of geometric imperfections, and runs in seconds to minutes. In this
tutorial, you will do the following:
- Learn to apply solar load for thermal steady-state analysis.
- Model Description
- The following model file is needed for this tutorial:
- Solar_load.ssp
Open Project
- Start a new SimSolid session.
In the main window toolbar, click Open Project
- In the Open project file dialog, choose Solar_load.ssp
- Click OK.
Create Temperature Constraint
- In the Analysis Workbench, click Temperature.
- In the dialog, verify the Faces radio button is selected.
In the modeling window, select the five faces
highlighted in orange in Figure 2.
For Temperature, enter 23℃.
Note: Ambient temperature in this case is 23℃.
Create Solar Load Boundary Condition
In the Analysis Workbench, click Solar
Load.
The Solar Loads dialog opens.
For Sunbeam direction, enter -1
along the y-axis.
In the modeling window, the direction of the sunbeam is denoted as a directional arrow in the triad.
Figure 3.
For Absorption coefficient, enter
1.
The value 0.01 denotes the minimum solar flux and 1 denotes the maximum solar flux. Solar flux is applied to the complete model in the modeling window along the specified sunbeam direction. The maximum solar flux (when absorption coefficient is set to 1) is 1412.11 W/m2.
Run Analysis
- In the Project Tree, open the Analysis Workbench.
Click
Solve.
Review Results
- In the Project Tree, select the Results branch for Thermal steady-state 1.
On the Analysis Workbench, click
(Results plot).
- Select the Temperature plot.
Adjust the legend settings to set the minimum value to
23℃ and the maximum value to
500℃ for better display of the temperature
contour.
Figure 4.
