SS-T: 4025 Modal Prestressed Analysis
Tutorial Level: Intermediate Apply prestress conditions to modal analysis.
Prerequisites
Some features used in this tutorial are only available in the SimSolid Advanced version. Switch to Advanced to complete this tutorial.
Purpose
SimSolid performs meshless structural analysis that works on full featured parts and assemblies, is tolerant of geometric imperfections, and runs in seconds to minutes. In this tutorial, you will do the following:
  • Learn how to setup prestressed modal.
  • Compare prestressed and non-prestressed modal results.
Model Description
The following model files are needed for this tutorial:
  • Crankshaft_Prestressed.ssp
Open Project
  1. Start a new SimSolid session.
  2. In the main window toolbar, click Open Project .
  3. In the Open project file dialog, choose Crankshaft_Prestressed.ssp
  4. Click OK.
Create Modal Analysis
  1. In the main window toolbar, click Modal Analysis.
  2. In the Number of modes window, specify the number of modes as 9.
  3. Click OK.
    The new modal analysis appears in the Project Tree.
Create Immovable Support
  1. In the Analysis Workbench, select Constraints > Immovable support.
  2. In the dialog, verify the Faces radio button is selected.
  3. In the modeling window, select the face(s) highlighted in orange in the figure below.
  4. Click OK.
    The new constraint, Immovable 1, appears in the Project Tree. A visual representation of the constraint is shown on the model.
Create Hinge Support
  1. In the Project Tree, open the Analysis workbench.
  2. In the Analysis Workbench, select Constraints > Hinge (Pivot) support.
  4. Click Apply.
  5. Click Close.
    A new hinge constraint appears in the Project Tree.
Create Structural Linear Analysis
In the main window toolbar, click Structural > Structural linear.
The new analysis appears in the Project Tree under Design study 1 and the Analysis Workbench opens.
Copy Supports to Analysis
  1. Under the Modal 1 analysis, right-click on Immovable 1 and select Copy to > Structural 1.
  2. Right-click on rotating hinge 1 and select Copy to > Structural 1.
Create Rotational Inertia
  1. In the Project Tree, click on a Structural analysis branch to open the Analysis workbench.
  2. the Structural 1 Analysis Workbench, click Inertia Load > Rotational inertia.
  3. In the dialog, click the Select a cylinder radio button and select the cylinder rotating hinge 1 is applied to.
  4. For Angular velocity, change the units to RPM and enter 5000.
  5. For Angular acceleration, enter 50 rad/sec^2.
  6. Click OK.
Create Modal Prestressed Analysis
  1. On the main window toolbar, click Modal > Modal prestressed icon.
  2. In the Modal prestressed setup window, select Structural 1.
  3. For Number of modes to find, enter 9.
    The new analysis (Modal 2, linked to Structural 1) appears in the Project Tree under Design study 1 and the Analysis Workbench opens.
Run Design Study
Solve all analyses in the design study.
  1. In the Project Tree, select Design study branch.
  2. Click Run All Analyses .
  3. In the Solver Manager, verify all analyses are selected.
  4. Click Solve.
    SimSolid runs all analyses in the design study branch. When finished, a Results branch for each analysis appears in the Project Tree.
Compare Results
Review the results for Modal 1 and Modal 2.
