SS-T: 4000 Static Structural Analysis
Tutorial Level: Beginner Perform a static structural analysis of a pullup bar assembly.
- Purpose
 - SimSolid performs meshless
                        structural analysis that works on full featured parts and assemblies, is
                        tolerant of geometric imperfections, and runs in seconds to minutes. In this
                        tutorial, you will do the following:
- Learn how SimSolid works
 - Create a comparison for SimSolid's workflow and results with those obtained with traditional FEA.
 - Model Description
 - There are two different pullup bar models used in this tutorial. Each model
                        has 33 parts. You will perform two static structural analyses for the
                            following:
- 2 load cases of 750N (168 lbf) total load on different handle locations
 - 2 different design configurations with varying support brackets
