SS-T: 4010 Structural Non-linear Analysis
Tutorial Level: Intermediate Run structural non-linear analysis in SimSolid.
Purpose
SimSolid performs meshless structural analysis that works on full featured parts and assemblies, is tolerant of geometric imperfections, and runs in seconds to minutes. In this tutorial, you will do the following:
  • Create structural non-linear analysis (material and contact).
Model Description
The following files are needed for this tutorial:
  • MaterialNonLinearity.ssp
  • Stress_strain_curve.csv
The project file has the following specifications:
  • Material is set to Aluminum for all parts.
Open Project
  1. Start a new SimSolid session.
  2. In the main window toolbar, click Open Project .
  3. In the Open project file dialog, choose MaterialNonLinearity.ssp
  4. Click OK.
Define Non-linear Material
  1. In the main menu, click Settings > Material database.
  2. In the dialog, right-click on the Sample non linear materials folder, and then select Add Material from the context menu.
  3. Select Add stress-strain curve....
  4. Click Edit.
  5. Import the Stress-strain curve.
    1. In the Stress-strain curve window, click Import CSV.
    2. In the Import units window, select Pa.
    3. In the File explorer, browse to Stress_strain_curve.csv and click Open.
    4. In the dialog, click OK.
    In the Edit Material database dialog, you can see the Elasticity Modulus was calculated from the imported stress-strain curve.
    Figure 3.
  6. Enter other values in the dialog,
    1. For Poisson's ratio, enter 0.33.
    2. For Density, enter 2.78e03.
    3. For thermal expansion coefficient, enter 2.32e-05.
    4. For Thermal conductivity, enter 1.21e02.
  7. Edit material name to Aluminum NL.
  8. Click Apply.
  9. Click Save.
Assign Materials
  1. In the Project Tree, open the Assembly workbench.
  2. Click (Apply material).
  3. In the dialog, click to expand the Sample non-linear materials folder.
  4. Pick Aluminum NL from the list.
  5. Click Apply to all parts.
  6. Click Close.
    In the Assembly branch of the Project Tree, material properties are identified for each part.
Create Structural Non-linear Analysis
  1. In the main window toolbar, click > Structural non-linear.
  2. In the dialog, select the Material non-linear check box.
  3. Click OK.
Create Immovable Support
  1. In the Analysis Workbench, select Constraints > Immovable support.
  2. In the dialog, verify the Faces radio button is selected.
  3. In the modeling window, select the face(s) highlighted in orange in the figure below.
    Figure 4.
  4. Click OK.
    The new constraint, Immovable 1, appears in the Project Tree. A visual representation of the constraint is shown on the model.
Define Pressure
  1. In the workbench toolbar, select Pressure→Uniform Pressure.
  2. Select the face as shown in Figure 5.
    Figure 5.
  3. For Pressure, enter -15 MPa.
  4. Click OK.
Edit Solution Settings
  1. In the Analysis branch of the Project Tree, double-click on Solution settings.
  2. In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
  3. Click OK.
Run Analysis
  1. In the Project Tree, open the Analysis Workbench.
  2. Click Solve.
Review Results
  1. In the Analysis Workbench toolbar, click Results plot.
  2. In the menu, select Displacement Magnitude.
    The Legend window appears showing the contour plot. The Results window appears. You can review the plot for different zones.
