Advanced
PhysicsAI tutorials with an advanced difficulty level.
PhysicsAI-T: 3000 Custom Inputs with a Global Hook
In this tutorial, you will use custom global input variables (such as varying material properties, global boundary conditions, and so on) for training.
PhysicsAI-T: 3010 Custom Inputs with a Nodal Hook
In this tutorial, you will use custom nodal input variables (such as varying nodal and elemental forces, boundary loads, and so on) for training.
PhysicsAI-T: 3020 Hook for Global Input and Output Vectors
In this tutorial, you will use hook variables for global input and output vectors.
PhysicsAI-T: 3030 Learn from Experimental Test Data
In this tutorial, you will train a PhysicsAI model without simulation results.
PhysicsAI-T: 3040 SER Training on KPIs
In this tutorial, you will use the Shape Encoding Regressor (SER) architecture.
