Split Quad to Tris
This option is used to split a quad into two-tri element. Scripting is supported here in order to record the working functionality.
Steps
There are two ways to split a quad element.
- Select a quad and a node from the quad element with respect to which it has to be split.
- Select one quad element. it will split along the shortest diagonal.
