Combine 2 Tris to Quad
This option is used to combine 2 Tris to quad.
Automatic: Turn ON the toggle to proceed the process automatically after picking the entity. Selecting the two Tri elements will automatically convert into a Qua element.
Note: Two element selected should be from the same face.
