setUICustomizationRepository
Overview
This utility is used to set the Repository directory for UI Customization (Advanced > UI Customization > Repository).
simlab.setUICustomizationRepository(Repository_path)
Use Case
To load the customization ribbon at the start of the SimLab application. Users do not have to select the repository manually.
Sample
simlab.setUICustomizationRepository("D:/MyCustomDialogs/")
