getCoordinateIDFromName
Overview
This utility is used to display the Coordinate ID for the corresponding coordinate name of the respective solution. The input argument is the Coordinate name.
simlab.getCoordinateIDFromName(‘CoordinateName’)
User Case
This utility can be used to get the Coordinate Id of respective Coordinate name , mainly used in case,where multiply Coordinate systems are used.
Utility Input/output
Sample
Note: Sample
Script
