Final step inside SimLab
The latest saved configuration of the part can be exported to be used in FluxMotor.
Specify a name and save path for the part.
On successful exports, a new folder is created containing:
  • An SLB file, accessible in SimLab
  • A folder with data for version control and display of the part in FluxMotor
Now, users can open the Part Library application in FluxMotor to import the newly created part and use it to perform motor test in the Motor Factory application.
