Checker
- Green check marks for valid criteria
- Red crosses for invalid criteria
When all validation criteria are satisfied, the Save Part Configuration button is activated, allowing the part to be saved using the current parameter values.
- Inner Magnet part, please refer to IM - Checker
- Outer Slot part, please refer to OS - Checker
- Inner Salient Pole part, please refer to ISP - Checker
List of common checkers that can be found in all types of part
- All bodies in the solution have a valid region
definition
Each body must be assigned to a LBC.
- Each body in the sector has only one region
definition
The assignment of each body must be unique, a body must be assigned to only one region.
- Structural parameter constraints are
validID, OD, and PN or SN parameter must exist, their values are numbers (not a formula):
- 0 < ID < OD
- PN is an even integer > 0 or SN is an integer > 0 (odd or even)
- Sector sketch does not contain wire body, spline or
ellipse
In the sketch of the sector, all lines must be connected, prohibited to use spline and ellipse.
- Sector surface is continuous
The part cannot contain discontinuous bodies; a body must touch at least another body.
The following case is not allowed:
- Sector is centered at the origin and aligned to the
X-axis
When looking at the relative position between the coordinate system and the part, only case among the following cases is valid:
- Sector boundary lies within valid
borderlines
All bodies must be within the inner and outer radii of the part and the two radial borderlines.
- Border line between Sectors are equal
Both right sides of the sector boundaries must be identical.
The next configuration is not acceptable:
- Sector parameter constraints are validVariable name and formula of constraints must respect the following convention:
- Variable name:
- limited to 50 characters
- can contain digits, letters (no accents), "_" character
- must begin with a letter
- not case-sensitive (if there is a variable "xy" then "Xy" must not be accepted)
- Comment:
- limited to 80 characters
- can contain digits, letters (no accents), space, and the following characters: ,.:;/()[]#&
- may be empty
- Variable name:
- No body fully encloses another within the sector
