Solid Pretension
User can model the pretension in the tightened bolt by applying solid pretension. Solid pretension can be modeled for the following solver.
- Abaqus
- OptiStruct
- Permas
- Nastran
- Ansys
- ADVENTURECluster
- RADIOSS
Pretension Section
If the pretension section is already there in the bolt, then user can directly select that section and define pretension. The pretension section can also be created by defining a plane where to create the section. If the input is bolt body and user select the option "Find", it will automatically find the pretension section
Solid pretension for Abaqus, OptiStruct, RADIOSS, Ansys and ADVENTURECluster
Pretension section card will be written out using lock option, adjust length and force.
Pretension node ID can be defined explicitly to define pretension loads like force and constraint.
Solid pretension for NASTRAN and PERMAS
Solid pretension for NASTRAN is modeled by two types of connection.
- MPC
- 2. Contact
Solid pretension for PERMAS is modeled by three types of connection.
- MPC
- Contact
- MPC-Type2
The bolt will be split into two halves and apart by the given gap, two RBEs will be created on the bottom face of the head portion of the bolt and top face of the thread portion of bolt respectively. The master nodes of these two RBEs will be connected by two bar elements and MPC will be created for the two nodes of bar elements as shown in the figure below.
ContactThe bolt will be split into two halves and apart by the given gap, two RBEs will be created on the bottom face of the head portion of the bolt and top face of the thread portion of bolt respectively. The master nodes of these two RBEs will be connected by weak spring with contact definition.
MPC-Type2The bolt will be split into two halves and apart by the given gap, two RBEs will be created on the bottom face of the head portion of the bolt and top face of the thread portion of bolt respectively. The master nodes of these two RBEs will be connected by two bar elements and pretension force will be applied on the two nodes of bar elements as shown in the figure below.
Create multiple section faces
- This option allows user to create multiple section faces above or below the plane defined in the bolt bodies.
- This is supported only for the following cases.
- Abaqus and OptiStruct solvers.
- Pretension section should be created using plane definitions.
- Bolt should be created using HEX elements.
- Multiple sections can be created for single bolt only.
Cards supported for various solvers
| Solver | Supported Cards |
| OptiStruct | PRETENSION (Subcase section)SURFPRETENSPTADDPTFORCEPTADJST |
| Abaqus | *PRE-TENSION SECTION*CLoad*Boundary, Fixed |
| Ansys | SECTYPE, PRETENSIONSLOADFD |
| ADVENTURECluster | $LinearConstraint$LocalCoordinateSystem$DisplacementLocalSystemID$Load$ForcedDisplacement |
| RADIOSS | /PRELOAD & /SUBSET |
