Group UI Right Click Options
Introduction
The following options are listed in the UI | Right-click for the group color display mode.
Display Body as Transparent
This option shows the non-group entities in transparent mode without face edge and group entities in group color. To display the face edges of the transparent bodies, turn the option in "Render Mode | Edge Display | Transparent Face Edge"."UI | Right Click | Hide Transparent Body" option is used to hide the transparent body, displays only the group entities.
Display Colored Entities Only
This option shows only the group entities by hiding the non-group entities.
Display in Body Color and Reset Model
These options turn off the group color mode and display the visible bodies in body color.
Redisplay Model, Redisplay Body
These options redisplay the active bodies in group color mode.
Display All Bodies
Turn off all the groups from the group browser hides all the bodies in the model. There are no models visible in the UI. This option displays all the models in the graphics.
