/TH/SURF
Block Format Keyword Describes the time history output variables for surfaces.
| /TH/SURF/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| obj_ID1 | obj_ID2 | obj_ID3 | obj_ID4 | obj_ID5 | obj_ID6 | obj_ID7 | obj_ID8 | obj_ID9 | obj_ID10 |
Definition
| thgroup_ID | Time history group
| thgroup_name | Time history group
name (Character, maximum 100 characters) |
| var_ID1, ..n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
| obj_ID1, ..n | Identifiers of the
surfaces to be saved (Integers) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| SURF | Surfaces | AREA, MASSFLOW, VELOCITY, P, A, MASS |
Table of Available Variables - Part 2
| Keyword | Variable Group | Saved TH Variables |
| SURF | DEF | AREA, P |
Output Variable for Surfaces
- AREA: Area of the surface (airbags, EBCS, pressure loads)
- MASSFLOW: Accumulated mass flowing through the surface (airbags, EBCS)
- VELOCITY: Flow velocity across the surface (airbags, EBCS)
- P: Average external pressure applied on the surface (airbags, EBCS, pressure loads)
- A: Surface area where external pressure is applied (pressure loads)
- MASS: Cumulated mass crossing the surface (airbags, EBCS)
- Variable names must be left justified.
- Available names are listed in the two
tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variables are listed. If a variable group is requested, all the associated TH-variables are written at once.
- MASSFLOW and VELOCITY are only available for internal surfaces of /MONVOL/FVMBAG1 and communication surfaces of /MONVOL/COMMU1. For these variables, surfaces must be defined by shell elements.
- P, A are available only from the load that is set by:
