/TH/TRIA
Block Format Keyword Describes the time history for a tria.
/TH/TRIA/thgroup_ID
thgroup_name
var_ID1 var_ID2 var_ID3 var_ID4 var_ID5 var_ID6 var_ID7 var_ID8 var_ID9 var_ID10
elem_ID elem_name
Definition
thgroup_ID TH group identifier.
(Integer, maximum 10 digits)
thgroup_name TH group name.
var_ID1, ...n Variables saved for TH (see table below).
(Character, maximum 8 characters)
elem_ID Element identifier.
(Integer)
elem_name Name of the element to appear in the time history.
(Integer, maximum 80 characters)
TH Output Keyword & Variables
Keyword Object Saved Variables
TRIA 2D tria VX, VY, VZ, SSP, MACH, VSTRAIN
Output for Tria
Output for Tria Available for Material Law
VX, VY, VZ All materials that are compatible with TRIA elements
SSP All materials that are compatible with TRIA elements
MACH All materials that are compatible with TRIA elements
VSTRAIN Volumetric strain
  1. Available names are listed in the two tables above.
    In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
    In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
