/TH/SPH_FLOW
Block Format Keyword Describes the SPH inlet/outlet conditions and control sections.
| /TH/SPH_FLOW/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| obj_ID1 | obj_ID2 | obj_ID3 | obj_ID4 | obj_ID5 | obj_ID6 | obj_ID7 | obj_ID8 | obj_ID9 | obj_ID10 |
Definition
| thgroup_ID | Time history group
| thgroup_name | Time history group
name (Character, maximum 100 characters) |
| var_ID1, ..n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
| obj_ID1, ..n | Identifiers of the objects
to be saved (Integers) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| SPH_FLOW | SPH flow gauge | FLOW |
Table of Available Variables - Part 2
| Keyword | Variable Group | Saved TH Variables |
| SPH_FLOW | DEF | FLOW |
- Variable names must be left justified.
- Available names are listed in the
two tables below.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variables are listed. If a variable group is requested, all the associated TH-variables are written at once.
- SPH_FLOW can only be used with /SPH/INOUT of type 2, 3 or 4.
- The flow can be filtered using a Butterworth filter. Refer to /SPH/INOUT for additional information.
- The contribution of a particle to the flow is considered positive if the particle cross the surface in the positive direction (according to the direction of the normal of the surface) and negative, otherwise.
